So I decided to mess with my Dahua intercom that has been working flawlessly since I installed it to try and get the push notifications working on my Android phone with the gDMSS app.
So....
Problem 1
I have 1 x VTO6210B (door station) I upgraded the firmware to from V1.0 to V3.1 and 3 x VTH1510CH (indoor monitors) with firmware V1.0. I have been unable to upgrade the firmware on the VTH1510CH. I get error message "Account is locked" or "Failed to clear config" when I use VDPConfig to try and update firmware.
I used Configtool v1.0.5 to upgrade the VTO6210B but it did not work to upgrade the VTH1510CH. It says "File transmission successful, system upgrading now..." but it doesn't finish.
I tried Configtool v2.0 but it hangs at "sending upgrade data...."
I tried Configtool v3.21 but it hangs at "All data transferred please wait..."
So, does anyone have any tips for upgrading the indoor monitor firmware.
Problem 2
My door station will only ring one monitor (master) and I can't add extension monitors in the web app under system config-> indoor manager. Everytime I try to add one it replaces the master.
Under Status Statistics-> VTH status - it only shows the master
All 3 VTH monitors show in VDPConfig with their correct IP address.
The extension monitors have a little door station icon in the top corner with a red cross.
I can't figure out what has changed in the door station settings that it doesn't allow me to add my extension monitors.
I filled out a support form on the Dahua website but that page just crashes. Great support.
So....
Problem 1
Problem 2
