thanks that worked.Like everything it's easy when you know it.
Right click on main screen, click Sequence.
Then just drag around the cameras to desired order and Apply.
Hi there, is there any way to change the sequence the cameras are shown on the DMSS app? I can do it on the NVR but don't seem to have an option to move on the multi-camera screen. You can drag and drop in the app but it doesn't save that view.
Your suggestion of rearranging the cables on the back of the unit WORKED! The ports on the back of my model are numbered and my cams are IP/Ethernet. I rebooted, and the NVR auto reassigned the channels to my desired order to 1, 2, 3, 4 for my sub screen monitor.There’s probably something in the settings but before tearing your hair out trying to work it, I’d change the cable connections around on the back of the unit or your poe switch but that’s only because I don’t know any better. If that didn’t work for me then I’d resort to reading the instructions (haha). Someone will come up the official procedure I am sure. I’d try on the preview screen where you can see all the camera views and try a left click or right click of mouse on the view you want to move and see if there’s a move option or whether it allows you to then drag to new position.
