Hi, I was researching Dahua and looking at their manuals and can't tell if their mounting system can turn enough to keep the wide FOV level with the horizon.
I want to mount it to a vertical wall instead of a ceiling.
Will the mounting system of this camera like the Dahua IPC-HDW4433C keep the 90-110 degree field of view from left to right, if I
mount it to a vertical wall?
I don't want to be stuck with the narrow FOV that is usually adjusts for camera tilt.
Thanks, Hector.
Thanks, Hector.
