Hi there,
I have a Dahua NVR5208-8P-4KS2 NVR. From what I have read in the manual, this supports two internal disks, but not using a RAID configuration. I have 4 x IPC-HDW5831R-ZE Cameras (8MP) plugged into the NVR and need to make a decision around the hard drives for this NVR.
Assuming top-res (H264), storing 7 days of footage @ 20fps. I'm fairly sure I need no more than 8TB. Can I ask for your help with the following....
1. Can anyone recommend a good NVR HDD calculator? I've tried 6 and got wildly differing values, from 3.8TB up to 8TB. I am specifying the same assumptions and would like to go for the smaller disks if possible!
2. For the Dahua NVR5208-8P-4KS2 NVR, can I put 2 x 4TB disks in, and then have 2 cameras feed to one disk, and the other two feed to the other disk? That way I can buy 2 x 4TB disks, which is cheaper than 1 x 8TB.
Thanks,
Chris
Thanks,
Chris
