Hi, I have a couple of the Dahua Ultra Series HAC-HFW3231E-Z cameras. In the camera's OSD's "Main Menu" under "Exposure" there are the following menu items:
Does anyone know what this Slow Shutter setting actually does?
(As a side note, to give some context, this camera is facing the street, so capturing crisp fast moving objects is important).
- Exposure Mode. I have set it to "Auto" and then turned "Low motion blur" on (this should in fact increase the shutter speed if I am not mistaken?), with the following settings:
- "Shutter max" is set to 33 (the highest it will go)
- "Shutter min" is set to 01 (the lowest it will go).
- Exposure Level: 12
- Gain: 8
- Slow Shutter (default is off), I have changed this setting to either "X2", "X4", "X8", "X16" or "X32" as well as setting it back to "Off".
