Dahua/ETech. On Reolink NVR
Defender574
Nov 11, 2024
39
13
USA
I want to add an Empire Tech cam to my Reolink NVR.
I need to plug it in to my network via port on my switch coming from my Eero first to log into the cam and configure the ip address before adding it to the NVR. My concern is it then has to be unplugged to then plugged into the NVR, so then wouldn’t it lose all the configured settings?
Do I need to add a switch somewhere in the line of things?
No it will not lose its settings when you unplug it and you only need to add a switch if that is what you need for your network topology.
Do keep in mind it may or may not work as planned giving it is Reolink and as discussed in your other post:
Okay thanks for your help. I’m probably going to end up switching over to blue iris and getting a NAS in the future. Hoping to get this to work for the mean time.
Got it working after of hours of messing with the ports. I really lose out on a lot of the features.
Would downloading a trial of Blue Iris and adding that empire tech cam to get a feel mess things up with it on my NVR?
At least you were warned LOL. Yeah it strips the features tremendously.
Normally we suggest that people can use the NVR as a POE switch of sorts to feed the camera to BI, but in this case, it would just send the video.
I would assume that either you assigned an IP address to the camera or the NVR did?
You would need to find the IP address of the camera and then disconnect it from the NVR POE port and provide power to the camera via wall wart or POE switch or POE injector.
Then put your computer on the same IP subnet as the camera and then give the free BI demo a try.
You would select ADD CAMERA and then type in IP address, username, password and hit find/inspect and let BI do its thing.
To bring the AI of the camera into BI, you would do the following:
Go into the camera GUI and set up smart plan with IVS, then go to the IVS screen and draw IVS rules (tripwire or intrusion box) and then select the AI you want it to trigger on (human or vehicle).
Make sure MD and SMD are turned off in the camera GUI.
Then in BI, there are a few places you need to set this up in BI (assuming you already set up the IVS rules in the camera GUI):
In Camera configure setting check the box "Get ONVIF triggers".
Hit Find/Inspect on the camera setting to pull the coding for the triggers. Make sure to re-enable substreams.
Go into Motion Setting and select the "Cameras digital input" box OR "ONVIF/CAMERA EVENTS" based on which BI version you have. Turn off BI Motion Detection (uncheck Motion Sensor) if you don't want to use it:
On the Alerts tab uncheck the Motions Zones tab (those are alerting you to any BI motion in those areas in Zones A thru H) and select ONVIF and External check boxes.
On the "On alert..." actions, select how you want to be alerted (email, push, SMS, etc.)
This will use the AI of the camera and not the motion detection within BI.
Reactions: Flintstone61
Woah man thanks for the detailed response!
I plugged the cam into my network and changed the ip with the ipconfig tool to my local ip with its assigned host number. It’s plugged into a Poe switch I added to my main house switch that I may use to power cameras if I go the blue iris route. The NVR detected it on the network, but it wouldn’t connect.
After hours of tinkering I needed to change the cams TCP port to 8999 and disable ONVIF login verification. Boom it appeared on my NVR.
Question is, now that I know the cams IP and all that. Would adding it to blue iris while simultaneously running on the NVR mess it up on my NVR? I don’t want to break anything now that I just got it working lol. I kinda want to mess around with blue iris to get a feel if I wanna ditch the NVR and transition into a blue iris setup.
Oh if it is on your network, then you should be able to have it go to the NVR and BI at the same time as the camera can have simultaneous logins.
The only issue would be if BI thinks the TCP port is something else, so if it doesn't automatically find it in the find/inspect then you will have to change the port in BI.
If you don't get an image, post what pops up in the window when you hit find/inspect and we can see what the issue is.
I greatly appreciate your help! Will post back when I have more time to mess with it.
Got the cam up and running with BI. Got everything working with the app aside from push notifications, can’t figure that out. I get alerts on the app but no notifications. Now debating if I’ll have to upgrade my PC to run the rest of the cams (ryzen 5 2600, 16gb Ram, rx570) or buy a mini pc solely for BI
Did you buy the BI app for your phone ($10)?
Most here use the Pushover app instead ($5).
The problem with the BI app for push notifications is unless you port forward (not recommended) or keep your VPN connected when off home wifi, you get the push without the photo.
Pushover allows the photo, but also has way more customization in how you get alerts, tones for each camera, etc.
But troubleshooting - you can access your camera on your phone? In the alerts section of BI you enabled push alerts? In the global phone setting in BI you enabled push? You don't have any restrictions on the phone for battery, etc. for the BI app?
Ahhh I figured it out, I was under the impression that the user's were activated when greyed out but it was the other way around. I ungrey'd them and it now works.
I like the feature with the reolink cams that turn the spotlight on when motion is detected under IR conditions. It that feature possible when switching them over to BI?
How does the pushover app do that?
That is a function of the camera itself, not BI. So if you set the camera up to do that, BI simply takes whatever video is fed to it.
Keep in mind most here don't use cameras like that as the switching of light can cause the exposure to temporarily wash out and miss the money shot of the perp.
You can set it up two ways - one way is it is sent via email to pushover email server and then pushed out to your pushover app. This could be done with an NVR as well to get around the requirement of P2P to get push alerts. The benefit to this method for an NVR is pushover only gets emails and if their server is hacked a hacker cannot get into your NVR like one could if they hacked a P2P server.
The other way is via an API command to pull the picture of the alert and push to your pushover app.
Ahhh gotcha. I already get email alerts with attachments on critical cameras and fortunately with my dedicated email server, they’re pretty quick
That works if you have a dedicated email where the only email you get would be from the NVR so that you are not getting email alerts at the middle of the night with junk email from some store LOL.
My email is set up that it only looks for email when I manually refresh so that I am not getting email dings at all hours with the junk type email from places you buy stuff from LOL.
Right, I just use the email as double confirmation when I hear the ding from the DMSS alert.
