Dahua / Empiretech IVS feed with Blue Iris - missing ONVIF source data field
Aug 1, 2025
3
USA
I struggled for 10+ hours to get IVS from my Empiretech/Dahua camera to feed properly into Blue Iris. I finally figured out the issue, so I thought I would share it here. The key thing I missed (and didn't see in the dozen or so other forum threads) was that I needed to add "00000" to the ONVIF source text box in the Network IP camera configuration menu - see step 3 below. I also had to add my own "listen for" rule to the ONVIF/camera events configuration menu - see step 7
Goal: use the camera's IVS features (not "motion detection" or "smart motion detection") to determine when a car passes my area of interest. I wanted to reduce CPU usage on my Blue Iris computer. I was also having issues with missed detections with Blue Iris motion detection (probably my fault - didn't spend much time configuring it).
Camera: EmpireTech IPC-B52IR-Z12E-S2
Camera Firmware: V3.142.0000000.4.R, Build Date: 2024-12-21
Blue Iris Version: 5.9.9.67
Here are the steps I followed from scratch. I probably missed something, but here goes:
1. Add new camera. Update username / password and change Discovery/ONVIF port to correct one before hitting "Find/inspect...". In my case, I changed the port to "80" to match the HTTP port from my camera.
2. Select the correct IP address from the "Find/inspect..." menu.
3. Check the box for "Get ONVIF trigger events". Also change the second "ONVIF source" text box to "00000" - see attached
Note: Changing the second text box value to "00000" was the important step that I missed for 10 hours. No idea what it means.
4. I made some other changes that shouldn't affect this, such as max frame rate, hardware decoding.
5. Motion/Trigger Tab: uncheck "Enable motion sensor" and check "ONVIF/camera events".
6. Click "OK" at bottom of window to configure the camera. This will ungrey the "ONVIF/camera events Configure..." button.
7. Motion/Trigger Tab: in ONVIF/camera events configure window: add a new rule:
contains: IVS
node path: Data/SimpleItem
Attribute: IsInside="true"
8. Alert Tab: I didn't have to change anything, but I did verify that "ONVIF" and "External" checkboxes were checked in the "Trigger sources and zones" section.
Empiretech/Dahua Camera Settings:
-Motion detection and Smart Motion Detection off
-IVS Rule enabled "Alarm-out Port"
-ONVIF enabled (network>basic services)
Other feature worth mentioning: In the Record tab, you can tell Blue Iris to save a JPEG to a specific folder. In this case, I save it to my AUX 1 folder, which I defined in the Blue Iris (not specific camera) settings, storage tab. This results in me having a folder with only the license plate captures. To avoid cluttering my database feed with these cars, I also unchecked "Add to the alert list" in the camera's Alert tab.
I'm still fine tuning everything, but so far extremely happy with my Z12 camera. It is much better than my $60 5MP reolink and amcrest cameras.
Thanks to the countless other forum threads on here - couldn't have gotten this far without this forum.
It shouldn't be that hard unless you changed a default setting on the camera and BI wasnt finding it.
For most of us, it is simply:
Add camera
Check the get ONVIF triggers
Type in IP address
Type in Username and Password
Hit Find/inspect
Done
Add camera
Type in IP address
Hit Find/inspect
Done
From reading the other threads, I see it does typically work out of the box for most. It’s quite possible I messed up a default setting somewhere, so thanks for sharing the “normal” / “expected” procedure for others. I just wanted to share what worked for me.
Yeah, I am trying to figure out where yours went south because all of that looks normal.
Maybe it was just some weird isolated error and glad you got it working!
One thing we have noticed is sometimes cameras with the new GUI do unexpected behavior when brought into BI if a factory reset of the camera wasn't done first, so many of us that is the first thing we do is a factory reset.
Good tip on the factory reset. It was a new camera, but I’ll have to remember that for the next one I buy.
Do you downgrade the firmware or just do a standard factory reset?
