Hi.
I'm trying to setup my camera, but it can't see micro SD... I own Samsung microSDXC 64GB EVO Plus UHS-I Class 10, used to try without formatting it - Camera doesn't see it. After formatting on other device - same problem... "No SD card found".
Also, i can't upgrade firmware to [PAL]DH_IPC-HX1X2X-Themis_Eng_P_V2.620.0000002.0.R.170830 Dahua Technology - Leading Video Surveillance Solution Provider with CCTV Products, IP Camera, PTZ, HDCVI products, NVR, Intelligent Building, Intelligent Transportation and Software - Dahua Technology
System Version:
Device Type . IPC-HFW1320S-W
System Version . 2.400.0000000.16.R, Build Date: 2017-08-31
WEB Version . 3.2.1.490211
ONVIF Version . 16.12(V2.3.1.458331)
Is there way to solve my problem? I'm about to return it back to store...
Thank you!
System Version:
Thank you!
