T Tpanda n3wb Dec 19, 2022 3 0 Trinidad Dec 20, 2022 #1 I'm trying to figure out if the Dahua DH-IPC-HDW3549H-AS-PV-S3 tioc has the ability to use facial recognition. I know they can detect human and vehicular movement but thought it had facial recognition as well.
L ludshed Getting comfortable Sep 14, 2022 649 822 Us Dec 20, 2022 #2 Only face detection, not recognition. Reactions: Tpanda
T Tpanda n3wb Dec 19, 2022 3 0 Trinidad Dec 20, 2022 #3 Ah ok, thanks so in your opinion which of these 3 would you recommend:- DH-IPC-HDW3549H-AS-PV-S3, DH-IPC-HDW3549TMN-AS-LED or IPC-HDW3541TMP
K kobebeef Pulling my weight Mar 13, 2016 229 246 Dec 20, 2022 #4 Tpanda said: Ah ok, thanks so in your opinion which of these 3 would you recommend:- DH-IPC-HDW3549H-AS-PV-S3, DH-IPC-HDW3549TMN-AS-LED or IPC-HDW3541TMP Click to expand... I will choose DH-IPC-HFW3549T1-AS-PV , without V3 or V4 Because only the first generation is F1.0 Dahua official website data error. Guess which one is for face recognition? Last edited: Dec 20, 2022 Reactions: Tpanda and JDreaming
