Q1. Does anyone know how to set up a pre-record value on the DB11? My other Dahua cameras have an option to set 5 seconds pre-record leader to any motion alarm, however the DB11 doesn't seem to have that option (SmartPSS shows 0s-0s). My DB11 is slow to react, and normally all the motion alarm recordings show people walking away in the distance.
Q2. How does one change the configuration to have continuous recording to the SD card? I tried changing the schedule but the DB-11 only records alarms.
Q3. How does one change to compression rate and frame rate? SmartPSS gives me an error message that it cannot retrieve Encode configuration. Most of other sections seem to work fine.
P.S.
Someone was asking what the max SD card was, I managed to format a 128GB micro SD with third party exFAT tools and it seems working fine with the DB11
P.S.
