Arrrrrghhhh.
Updated the firmware on a IPC-HDW5442TM-AS to V2.840.0000000.30.R, Build Date: 2025-02-27 ( DH_IPC-HX5XXX-Volt_MultiLang_NP_Stream3_V2.840.0000000.30.R.250227.bin ) and I now have problems with the camera speaking to the web interface everytime it tries to run a day/night profile switch, its not connecting. Here's the log;
0 18/10/2026 08:17:02.128 Cam20 Event: PTZ Preset 2 (2202) paused=0
1 18/10/2026 08:17:07.244 Cam20 Web: Connect: 8000007b
1 18/10/2026 08:28:13.317 Cam20 Signal: network retry
1 18/10/2026 08:28:34.410 Cam20 Signal: Socket error
1 18/10/2026 08:28:43.317 Cam20 Signal: network retry
1 18/10/2026 08:29:04.238 Cam20 Signal: Failed to connect
1 18/10/2026 08:29:13.446 Cam20 Signal: network retry
4 18/10/2026 08:29:19.888 Cam20 Signal: restored
0 18/10/2026 08:30:25.737 Cam20 Resetting
1 18/10/2026 08:30:38.910 Cam20 Web: Connect: 8000007b
You can see what's going on, the Preset 2 switch command is sent from the camera but the command doesn't appear to get through to the V3 (the grey and black one) web interface for some reason and is rejected/ignored with a "Web: Connect: 8000007b" response. This worked perfectly before the upgrade.....yes, I know don't upgrade unless you really, really need to. In my case, the firmware was years old and thought it might have a few extras or fixes I might like....lesson learned the hard way!
Anybody know what's going on and what the fix might be? I tried various things like Find/Inspect, rebooting etc but anything that might help just results in the 8000007b error. Funnily enough, the web interface can talk quite happily to the camera but it appears the camera can't talk to the web so I'm back to using the Sunrise/Sunset utility for the time being........lifesaver!
EDIT: A thought, I only installed the one main upgrade file, should I have also installed "firmware.bin" and/or the smaller 10kb file??
DH_IPC-HX5XXX-Volt_MultiLang_NP_Stream3_V2.840.0000000.30.R.250227.bin 91,202kb
firmware.bin 44,971kb
DH_IPC-HX5XXX-Volt_MultiLang_NP_Stream3_V2.840.0000000.30.R.250227.bin 10kb
Thanks for any help that can be provided.
