Hi,
I was wondering has anyone ran into a similar issue where motion detection does not record events nor gives alerts from one converted (analog->IP) channel.
I recently bought a Dahua XVR recorder (DH-XVR5108HE-4KL-I3). I have seven analog and six IP (Wi-Fi) cameras in use. I have converted the last analog channel to IP, and this is the one I am having problems with. No matter how I configure this channel, it will not record any motion detected events.
I have tried with three different IP cameras which work fine on the actual digital channels (9-16), but once I configure them to this converted channel #8 the MD does not record anything. The constant recording works fine. I even copied all the setting from a channel which works but no luck getting it to record motion detected events on the converted channel #8.
So, the question is if there is a setting I am missing here? Only MD selected (no AI), MD recording activated. Recording for normal, event and alarms from 00:00-23:59 activated for all weekdays. Furthermore have tried sensitivity from 10 to 100 and many different resolutions.
Somehow it looks like the converted analog channel does not operate the same ways as the “real” IP channels from 9 to 16 do.
Another thing would be if I cannot get the channel 8 working can it be removed from the DMSS app and/or XVR so it would not show an empty screen in the middle? XVR with PC connection gives the option to re-arrange the channels but DMSS does not?
Any help would be much appreciated.
