Hey guys,
I am looking for the Dahua config app. I have found a few links, but none of them are called the "Config App". I think this is the most likely culprit, but want to confirm 100% before continuing.
Toolbox
I also want to make sure that, assuming it is the Config App, this is the correct application to use for initial configuration on the cam. From what I have read, the default IP is 192.168.1.108 with the default admin/admin id/password combination. If for some reason I can't connect, then I need to "reset" the camera which might have a button or two metal prongs that need to be shorted on start.
Thanks for any help/guidance.
Toolbox
