I am talking about the built in cable from the camera.The connections on the RJ45 connectors and cabling from your network switch to your port that the camera connects to are industry standard, nothing to do with Dahua.
Is there something wrong with the RJ-45 female connector on the cam's pigtail?I am talking about the built in cable from the camera.
I do.So you don't know the model number of the camera?![]()
Then tell US for God's sake, this is essentially the 3rd time I've asked...it may help someone else. Do you have something against that?I do.
And that wiring worked
Thanks
Did you see the picture of the pigtail?Best practice would be to disconnect the RJ45 male (network cable) from the RJ45 female (camera harness) using the tab on the male RJ45 connector. This is preferable to cutting the camera harness, at least where I'm from.
