- Jul 25, 2015
- 68
- 47
Any video experts wanna take a crack at clearing up this footage to make out license plate?
The main technique that might enhance that plate would be interpolation. Individual frames from the video where the car is stationary could be extracted and then combined using interpolation. I don't like your odds though, there just aren't enough pixels on target. You need to be zoomed in a lot more.I've tried After Effects and Premiere but Im a novice at best so it wasn't much help. I feel like there is enough there for software of some sort to get a clear image. Just not sure what im doing.
The zoom typically zooms great. My zones have worked very well. I normally would have gotten a great close up. Somewhat of a fluke I think. Then to compound the matter there is a time limit before it will re-aquire a motion target. He came in somewhat on the wrong side of the roadI'm going to see if I can tweak that setting. I'll also look into "interpolation." That sounds like exactly what I had in mind but I didnt know what it was called. Thanks!The main technique that might enhance that plate would be interpolation. Individual frames from the video where the car is stationary could be extracted and then combined using interpolation. I don't like your odds though, there just aren't enough pixels on target. You need to be zoomed in a lot more.
Generally at night you are better off in IR mode. Getting a good plate capture often requires a dedicated camera with lots of IR light and short exposure times. The plate will light up nice and bright and the rest of the image will be very dark.
How many other cameras do you have and what are you using to record them? Auto tracking doesn't seem to be zooming in enough for a useful capture. Assuming you have other cameras, try to set it up so that an intrusion in a particular area like the mailbox triggers the PTZ to switch to a preset that much more zoomed in. Even just parking the PTZ on a preset that's zoomed in so the entrance to your cul-de-sac takes up the full width of the image would be better. That PTZ has lots of zoom USE IT!
Are you using blue iris or an NVR? I feel like most of the night time videos you've shared would have benefited from more zoom and/or IR light.The zoom typically zooms great. My zones have worked very well. I normally would have gotten a great close up. Somewhat of a fluke I think. Then to compound the matter there is a time limit before it will re-aquire a motion target. He came in somewhat on the wrong side of the roadI'm going to see if I can tweak that setting. I'll also look into "interpolation." That sounds like exactly what I had in mind but I didnt know what it was called. Thanks!
