Hi
I am looking at putting 3 camera at the front of the house. POE and a NVR.
I saw Wittaj said
At the front door which also has bright security lights, i was thinking of this
Dahua TIOC Advanced 2.0 DH-IPC-HDW3849HP-AS-PV-0280B-S3 Dahua 8MP AI Active Deterrence Full color Starlight IP Turret Camera
I realise its a 2.8mm fixed lens combined with a 8MP but right at the front door with bright light at night it should be fine.
I was thinking of then putting the same camera on the driveway (only lights around are the up/down lights on some nearby walls) but realise i should go for lower MP? can people point out a DAHUA model that meets this need? note the Australian link above as I am in Australia.
Also what do you think of the
thankyou
I saw Wittaj said
A few other tips....It is simple LOL do not chase MP - do not buy a 4MP camera that is anything smaller than a 1/1.8" sensor. Do not buy a 2MP camera that is anything smaller than a 1/2.8" sensor. Do not buy a 4K (8MP) camera on anything smaller than a 1/1.2" sensor. Unfortunately, most 4k (8MP) cams are on the same sensor as a 2MP and thus the 2MP will kick its butt all night long as the 4k will need 4 times the light than the 2MP... 4k will do very poor at night unless you have stadium quality lighting (well a lot of lighting LOL).
vs
Dahua TIOC Advanced 2.0 DH-IPC-HDW3549HP-AS-PV-0280B-S3 Dahua 5MP AI Active Deterrence Full color Starlight IP Turret Camera
thankyou
