One of my version 2 boobie cams has started flashing the IR lights on and off all night. Tried rebooting but no luck. Any ideas on how to fix this?
Thanks
Thanks
Toggle setting of "Smart IR" ?One of my version 2 boobie cams has started flashing the IR lights on and off all night. Tried rebooting but no luck. Any ideas on how to fix this?
Thanks
Thank you, will try it.Toggle setting of "Smart IR" ?
It has been fine for almost a year now. Not sure what good be affecting the settings. Will try.
If no recent environmental changes (wall painted, new light fixture, another cam facing it, etc.) and if no changes to the settings I mentioned above help, consider a hard reset of the cam.It has been fine for almost a year now. Not sure what good be affecting the settings. Will try.
Thank youIf no recent environmental changes (wall painted, new light fixture, another cam facing it, etc.) and if no changes to the settings I mentioned above help, consider a hard reset of the cam.
It is indoors, in a clean area.Any chance you've already cleaned all the cobwebs and debris that has collected on and around the camera?
May have to get 1!So not an actual disco boobie cam??
I found Hi Sharp online... seems they are the OEM for some TVT cameras.
