is there a trick to getting the dahua HD app to play nice with my cams? i have never had an isuue with ip cams and apps before. i forward 3 different ports and have tried all 3 with no luck. i did one port via TCP, one port UDP, and one port as "both TCP/UDP." my local IP is correct and static as far as port fwding goes. im lost. any assistance it appreciated.
i can access the cam locally, but not with my WAN ip, so clearly i am doing/did something wrong.
my default gateway is correct as well.
