Dahua AI, How to search AI triggers without NVR (camera only)
Andydogga
Dec 30, 2018
35
4
Australia
I have a few remote solar cams and AI events work great to the phone app. But I was hoping to be able to pull up AI events over a week period but with smart pss or using the link to the web browser page but I can't see a work around? Maybe with snapshots?
Also has anyone used anything bigger than a 256Gb card in these cameras with success (5442-ZE Turret)? Thanks
Be sure you're using Internet explorer or Chrome with the IE tab plugin installed. Then be sure to download the plugin from the camera when it asks you to. You then will be able to play back videos from the web interface and sort them by AI type.
Thanks looney, I have found different firmwares behave differently and I’m finding it won’t play back Ivs events independently. Under alarm event it says no record, I don’t believe there is an Ivs option in the ie playback.
