Dahua 608-32-4KS2 Browser Web Plugin Problem
botics
Getting comfortable
Feb 9, 2019
250
116
Coral Gables, Florida
Model: 608-32-4KS2
System Version: V3.216.0000000.0
Build Date: 2018-10-09
Logging into the NVR I can only view my cameras in Internet Explorer v11 running on Windows Pro 10.
Firefox and Edge will ask me to install the web plugin when I go to preview the cameras - I have installed the web plugin several times. Is anyone else having an issue with the web plugin? Any solutions?
Reactions: Shams
Use Pale Moon 32 bit to log into your cameras and the web plug in will work.
Reactions: botics
The other browser are restricting plugin usage do to security issues with plugins.
The plugins may not work for multiple cameras from the same vendor as the plugins have the same name , but completely different code.
If I need to use the plugin , i first delete all the plugins and start again with one camera and one plugin.
I do not see much need to use the browser to look at video from the cameras
The only reason I want a web browser is sometimes I sit at my desk and I can have the cameras on another computer monitor. What are you using to view your cameras?
I run blue iris. I use he ui3 web interface.
I am getting ready to fire up BI that's the next project. Seems like the NVR while useful BI has more control.
With the Dahua cameras you may also want to check out Dahua SmartPSS
Reactions: weigle2
