That's an analog cam, not an IP cam.hi everyone i have iusse this model picture its showing dubble shadow
same wire same xvr if i fix 2mp or 4mp cam working fine when i connect 5mp model same iusseThat's an analog cam, not an IP cam.
Are there any other cams attached to that NVR?
If so, are any the same model as the one that has an issue?
Let's not debate semantics...an XVR is still a network video recorder (NVR) that can work with analog or IP cameras, hence the XVR tag of which I am aware.and there is no NVR only XVR which is post
Looks like your CVI camera coaxial or connections are causing the issue. Never seen a CVI camera cause that issue. Check the coaxial cable BNC connectors and cable.
