H heroine_n6600 n3wb Dec 27, 2017 8 10 Nov 4, 2021 #1 After upgrade to latest firmware, the 5216-16p-i capture the same image TWICE on AI mode. before the upgrade, it was fine with one image captured. Is there anyone have the same issue? Attachments IMG_20211105_115104.jpg 2.3 MB · Views: 14
looney2ns IPCT Contributor Sep 25, 2016 16,331 24,236 Evansville, In. USA Nov 4, 2021 #2 Did you set the NVR back to defaults after the firmware update?
H heroine_n6600 n3wb Dec 27, 2017 8 10 Nov 5, 2021 #3 I will give a try. I did upgrade the NVR firmware few times before, never set back to defaults.
H heroine_n6600 n3wb Dec 27, 2017 8 10 Nov 5, 2021 #4 looney2ns said: Did you set the NVR back to defaults after the firmware update? Click to expand... Tried default and factory default. Same result. More than one images were captured Attachments IMG_20211105_172549.jpg 1.6 MB · Views: 7
