hmjgriffon
Correction, if you can get them to run linux or a mac they will be fairly well protected from themselves lol. which is the other reason I don't fool with AV, I run linux most of the time.
Agree 100%Correction, if you can get them to run linux or a mac they will be fairly well protected from themselves lol. which is the other reason I don't fool with AV, I run linux most of the time.
The independent lab tests show otherwise... Users are incompetent either way...No need to make it easier for them...Totally disagree, no need for any anti virus with win 7 or 10 and if you install it on a users computer most likely they believe their bulletproof .
AV-TEST – The Independent IT-Security Institute
Did you read the charts... Norton provides 100 percent protection over zero day attacked...costs me 6 dollars per pc...The CPU use is undetectable....You obviously never managed a group of user's...You can scream until your face is blue...Won't help... Furthermore any website can be subject to attack even the blue iris update website...So not having protection is stupid... Recommending folks not using antivirus is dangerous and foolish...If folks would be protected we would all have less problems...These test don't matter, the point is most viruses these days are "zero day viruses" and the user should be educated on what to do and what not to do . Again no reason to install a antivirus that just takes up CPU and memory. It's a complete waste of resources and it doesn't matter if it takes a little bit of resources or alot it's a waste. This would be like installing a new camera in BI and pointing it at the wall.
I have windows 10 pc that is dedicated only for bi and nothing else, I have a laptop for everything else. I was thinking that windows defender was enough now you guys got me worried if its enough.
I guess i'll have to get norton, it's a small price to pay and not have to worry about it.
you should really learn how to use the multi-quote function on the new forums @hmjgriffon, just hit the +Quote
unless your just trying to inflate your post count, then tha'll work against yeh![]()
Windows is just fine...really....Sorry, gotta go against you, if more people stopped using windows we'd all have less problems lol!
