Hi all!
I am new here but I found lots of useful discussion in the forum.
I have a problem with an IP-CAM POE powered (the camera is powered for sure since that once connected to the PoE router its leds goes red), that does not appear on the IPCAM original setup wizard niether in the router assigned IP within the network.
I tried to reset the camera by using the button inside as suggested by the munal for complete reset, but nothing happend - it seems that also pressing it does not cause a reboot as the camera led always stays on.
Any suggestion?
Thanks for any possible help/insight you may have!
BR,
Steven
Any suggestion?
BR,
Steven
