Custom SSL certificate upload for HikVision NVR
suprovsky
Sep 30, 2024
1
nothanks
Hey, I have a DS-7764NI-M4 with firmware V5.04.065 build 250530 (latest) and I am trying to deploy a custom SSL certificate, as we covered all appliances in the company with certificates coming from the company PKI...except this device. I tried contacting HikVision several times, but all they do is ghost me. So I asked a HikVision distributor who ended up attempting to help, but since the best they got from HV was a guide you can get by typing "how to ssl certificate hikvision" in Google they ended up ghosting me too, so after waiting for almost half a year for support I thought I'd ask here.
The way you do it:
When you go to the Maintenance and Security -> Security -> TLS, you have three options for installing certificate:
- create a self-signed certificate (we don't want this)
- a signed certificate is available, install now (we want this, since I have a certificate generated with a key in PEM format, with private key included at the end so we still keep it in one file and not as PKCS12 format)
- first create a certificate signing request, then continue installation (you fill up a form to create a CSR and NVR stores a private key, you get a certificate signed by your CA, then you upload your certificate to NVR and it should work)
In order to actually have access to these options you have to disable TLS usage entirely (disable HTTPS and enhanced SDK service).
The problem:
- well, when you attempt to upload a file regardless if you use option two or three, you always end up with the same error: Upload failed. It seems that there is even no attempt to send the file, because any file I sent I get the same error, like the website does not even try to upload it.
I tried also the second option, pretty much with the same result - the website does not want to upload the file.
Have any of you managed to get this to work? I'll add that we have two NVRs in the company and the other from Dahua didn't give any headache like this. Worked plain and simple.
