- Dec 15, 2017
- 135
- 45
...:sigh: Dude this forum is going to rip you up. Do some research and search the forum, it's that simple.
It is, except for lazy folks....Sounds like an extremely friendly forum...
Im getting a bit confused by all product numbers, so just putting out the question here:
As of December 2017, what is the best all round PTZ Dahua dome camera for outside use (model number) that is sold on ebay (or so) - how to spot real / fake versions and also is supported by Blue Iris?
Welcome alekslyse,
Skip ebay and check out #15 in my notes - look for a Dahua starlight PTZ - lots of great options there, iirc starting around $3xx.00
It's easy to get swamped with information here, so I wanted to share some notes with you
Please check out @giomania 's notes:
Dahua Starlight Varifocal Turret (IPC-HDW5231R-Z)
I have also made notes which are a summary of a lot of the reading I've been doing here,:
Looking for some advice and direction!
Have fun joining us here.
Thank you. I decided to go for 6 PC-HDW5231R-Z and two POE switches. Is it any benefit of using "branded" Dahua switches or will everything work? I sent a list to a couple of dealers including the ali express one that seems to be popular in here so lets see what I can end up with.
