Current Stable Release for BI?
Alaska Country
Getting comfortable
Jun 10, 2021
659
916
Alaska
Using 5.9.07 and its time to update to a newer stable update.
However, the BI computer is 100% isolated from the net and the BI update functions does not work without the internet. Did add a DEMO BI install to another computer thinking that was the solution, but that will not display any version update information.
It would be nice of the BI Update Listing on IP Cam perhaps had an extra line of text added to indicate the latest stable version.
Looks like 5.9.3.4
Go to updates, download, put on flash drive and take to the site.
I agree that would be good to have that info, just as you mentioned back in May. Have you considered e-mailing BI support with that request?
Thanks for the update version number. That is exactly what is done. Download on the net connected computer and then placed on the BI machine. They are 3 feet apart. Too bad the sneakers are in bad shape as they have trouble making that long jog over to the other system!!
Will have to write support and ask. That would be a nice plus on the download site. Perhaps as simple as placing an asterisk by the latest stable version or just an "S" as part of the version number.
Thank you both for you assistance and conformation.
Reactions: looney2ns and TonyR
