Hello,
I decided to post here, maybe someone has an idea on how to solve this.
This Ctronics CTIPC-S20 device has functioned normal since initial setup, up to the point the network was set on become unavailable.
Did attempt to reset it via the reset button (pressed for 10-15 seconds) and re-provision it via the Ctronics mobile app.
Problem is that now I only the the restart sound and not the reset(looking for configuration) chime it did initially.
Tried to set it anyway via the sound method or the QR to lens, but no reaction.
Removed the SD card, same result with it off or on.
Opened the devices and cleaned it up, was thinking maybe dust or some other blocker, but nothing like that.
Running out of ideas on how to reset this.
Any help is appreciated!
