Hello All
Working out the routes for cabling to at least two of my external camera locations and I will have to cross 240v mains supply cables
What is the best way to do this & does the Cat6 cable need shielding in any way (to avoid interference)
The cables I need to cross are fitted externally to mine & adjoining properties are are the main electrical feeds to our properties
We're in the UK so its 240 volts at 50 Hz if that makes any difference
My Cat6 cable is unshielded so I'm wondering if I need to shield the cable somehow - and if so, which is the best way of doing it
I know that I need to cross the power cables at 90 degrees
Thanks in advance for any replies
