i've been here for a lil while, but haven't posted much. Thought i'd post some pics of my Hikvision install and see if any of you folks would suggest i do anything different. I also have a fourth camera coming that should be here next week to cover my back yard
The front door cam is a DS-2CD2385FWD-I 2.8mm, the two side cams are DS-2CD2042WD-I 4mm. the one on order is a DS-2CD2335FWD-I 2.8mm, which will go at the front door, and the 2385 will go in the back yard. I'm also in the process of adding IR illuminators to put around the property.
