- May 6, 2018
- 11
- 8
Hi all,
I was wondering if I could get a second opinion on the design I have so far come up with and answer the questions I have below?
So I am buying a currently being built house and I have the opportunity to run cables wherever I like. Due to this I am going to install CCTV and I believe I require 6 IP cameras to ensure as close to 360 degree coverage as possible.
I was considering buying the Hikvision DS-2CD2185FWD-I cameras as my camera of choice. My reasoning behind choosing this camera is primarily because it is newer over my second choice of camera the Hikvision DS-2CD2142FWD-I. The cameras will be powered by a 48 port Cisco Switch (WS-C3560G-48PS-S).
I believe I require three 2.8mm and three 4.0mm lens lengths. I’ve based this on the information for the DS-2CD2185FWD-I camera from the specification page here and my totally expert graphic design skills in my design below. I've included the appropriate angles for the specific camera on the design below.
As the house isn’t yet built I have no way to provide pictures to assist in helping get my point across. I do, however, have some simple plans of the house which I have linked below. The house is set on a development with street lighting (of course I am not sure where) and thus I do not believe night lighting will be an issue.
An explanation of the colouring:
- 2.8 mm, horizontal field of view: 102°
- 4 mm, horizontal field of view: 79°
- Yellow building is the garage which is 6m long
- Green section is a one storey extension
- Blue section is a porch area
- Camera 1 – 2.8mm lens length
- Camera 2 – 2.8 mm lens length, placed within porch area
- Camera 3 – 2.8 mm lens length, placed on the gable wall facing the ground
- Camera 4 – 4mm lens length
- Camera 5 – 4mm lens length
- Camera 6 – 4mm lens length
- Is my design correct?
- If not is there anything I should correct?
- Will the DS-2CD2185FWD-I cameras serve me well in this situation?
- Where can I buy these cameras in the UK? I have found them on eBay but I am concerned regarding ‘grey market’ devices. Everywhere I have looked outside of the likes of eBay wants you to sign up as a trades account – Hikvision wants you to get these cameras legitimately but when I try to do so I’m finding it difficult.
