I picked up these a year ago and haven't had one fail yet. Amazon.com: Intellinet 100 Pack Cat5E RJ45 Modular Plugs Standard (790055): Electronics
Agree with that. I've resigned myself to throwing away 2 to 3 inches of wire on each end to cut the time and aggravation way down.I also learned to leave the ends "Extra" long to get the wires into the holes on the inserts. I can't do it the way experts on Youtube do that looks so simple.
I don't own the ez crimper myself, but there's nothing easier or faster. They are also nicer to work with up on a ladder.I line the wires up, push them into the ez connector and they pop out of the end, verify, crimp/cut done, is it the cheapest? No, but it's easy and they are perfect Everytime, you just have to decide what your time and aggravation is worth to you.
This presents a few problems. 1) its a mess to do and protect from the elements on the camera side unless you do it all in wall which requires a larger hole, or access on the back end. 2) it creates attenuation which on longer runs can be problematic. 3) it introduces another point of failure.Instead, they run the wire to punch down keystone blocks (the type that have a provision for a zip tie to hold the wire tight to the block), then make the final connection with good quality, factory made ethernet cables.
