C CK IP Camera n3wb Aug 9, 2017 27 3 Dec 29, 2025 #1 Hi, I hope somone can help. I get the above message when attempting to send emails either from Alerts or from the Test button within the Action Set list. When I hit test from within Settings/Email servers it works fine though. The settings are as follows:
Bruce_H Getting comfortable Feb 22, 2017 708 342 Ontario, Canada Dec 29, 2025 #2 A quick search on the internet finds this Ensure that the EASendMail ActiveX component is properly registered on your system. You can try to register it using the command: regsvr32 "C:\Program Files\Blue Iris\EASendMailObj.dll"
Bruce_H Getting comfortable Feb 22, 2017 708 342 Ontario, Canada Dec 29, 2025 #4 CK IP Camera said: That worked perfectly, many thanks Bruce Click to expand... Glad it worked for you, it was a bit of a stab in the dark!
