- Sep 14, 2015
- 1,197
- 3,977
A small tractor being loaded onto a trailer, slips off the ramps and crashes in the street.
I sure that was all OSHA approved.
Bet he has a sore back and neck in the morning.
Wow, did you just load a golf cart into a mini van??Yes, never try to drive it onto ramps uphill. I have a Cricket that we take on RV trips. It gets loaded into the back of my Jeep with ramps. Even in the slope of my driveway, I always load it downhill.
View attachment 142964View attachment 142965View attachment 142966View attachment 142967View attachment 142968
Not a minivan. It is a 2015 Jeep Grand Cherokee. We tow it behind our motorhome, which is parked on the right-hand side of the photos.Wow, did you just load a golf cart into a mini van??
Yes, after getting it working, he loaded it on the trailer on the down slope. He had to refill at least 3 different fluids before he tried to restart it. The engine started right up. Those little tractors must be hard to damage.Appears to be loading up hill instead of on the down slope.
Did he try it again?
I wonder if he pulled the plugs or injectors and spun the motor over with no compression. If the motor had been hydro locked from laying on its side, he could have easily bent a connecting rod or broke the crank. Seen that happen a few times.Yes, after getting it working, he loaded it on the trailer on the down slope. He had to refill at least 3 different fluids before he tried to restart it. The engine started right up. Those little tractors must be hard to damage.
