I am writing because I have an issue that I am not able to resolve that resolves around the CPU usage spiking to 100% when I enable more then 6 cameras and the CPU affinity is set to use all CPUs.
System Setup:
VM - Windows Server 2012, 8GB RAM, 2TB Drive, Intel i5 2.4 Ghz
Cameras - 9 x Hikvision DS-2CD2332-I RSTP steaming
I have had this same setup for over 2 years with no issue. I have been on every forum and tried all of the suggestions, from reducing Motion Detection sensitivity to setting up Direct to Disc. I increase the RAM, number of vCPUs and nothing is changing the outcome. I am using the most up to date version and I even went back to version 4.0.0.13.
Do you have any other suggestions to resolve this issue?
System Setup:
