I've seen older posts on this subject but wondering if there's a newer fix. Computer is I5 core at 3.9ghz, 16gig ram, Asus maximus hero vii moboard, Nvidea gtx260. The cpu stays up between 97% and 99%....it is warm at 145 farenheit but not overheating. Live view and recording are fine. It only affects things when trying to do something else on the computer, like a browser, which freezes for awhile or takes a long time to open.
Tried frame rates down to 10 on all the HD cams ( 14 of them ). No pre-record. Tried raw recording to disk ( no encoding ) on all cams except the 4 1080p's because it distorted the playback. On those encodings I lowered the quality to 50% which is sad when you're trying to do HD. Turned off jpeg snapshots. Tried lowering the bit rate to 2000 on these cams which are various Dahuas. Tried unclicking the motion record and used the camera's motion, but then it doesn't record at all. You'd think you could offload motion to the camera - which would reduce cpu load a lot. Am I missing something? The Dahuas are setup as an RTSP feed as there's no manu's listing.
Would an I7 make a big difference ? The dahua smartPSS software runs at around 50% cpu but that entirely uses cam's built-in motion. ( It's a shame the smartPSS doesn't playback or record reliably, compared to BI ).
Any help would be greatly appreciated!
Thanks
Thanks
