N nebbiadigiorno Young grasshopper Jan 29, 2016 53 1 Nov 11, 2017 #21 yes, with all the remote session close the cpu for bi is 22-23%
fenderman Staff member Mar 9, 2014 36,891 21,411 Nov 11, 2017 #22 nebbiadigiorno said: yes, with all the remote session close the cpu for bi is 22-23% Click to expand... there you go...
N nebbiadigiorno Young grasshopper Jan 29, 2016 53 1 Nov 11, 2017 #23 ok so there is not an "answer" for my problem, if i want an x number of remote question i will have a tot amount of cpu usage.... thanks
fenderman Staff member Mar 9, 2014 36,891 21,411 Nov 11, 2017 #24 nebbiadigiorno said: ok so there is not an "answer" for my problem, if i want an x number of remote question i will have a tot amount of cpu usage.... thanks Click to expand... the biggest hog is teamviewer...dont use it except for making settings changes.... then you can play with the webserver profile settings if you wish to reduce cpu usage for remote sessions...
N nebbiadigiorno Young grasshopper Jan 29, 2016 53 1 Nov 11, 2017 #25 there is a wiki or a thred for the web server option?
