CPAI Error 500 or not responding
Trix
Mar 8, 2024
2
Netherlands
HI All,
We have a business setup with ~30 cameras on a 13th gen i5, 64GB RAM, and a 70TB NAS attached.
Currently we encounter a lot of AI not responding errros, whereas most notifications do get pushed through.
I'm an perfectionist, and would like these errors gone. What can i do about this?
Thanks! (:
I see in the change log the following, have you looked at the settings that are referred to?
[5.9.9.25] AI changes designed to reduce the occurrence of the dreaded “not responding”
condition. A maximum number of connections may be specified. When this limit is
reached, analyses will be queued until resources become available. Previously, a single
connection (network socket) was used for all module requests; now, a socket is created for
each module used during an analysis. You may also specify a number of minutes of AI
uptime before the service is automatically restarted. You may select individually which
custom modules are considered for use globally on Settings/AI.
The inception of a new status window Overview page. This page now shows AI status along
with basic system metrics like CPU, GPU, RAM. The number of AI connections and the
response time for all modules is presented. Still much more to come here…
