I'm running CPAI 2.9.5 and BI 5.9.9.23. Overall it works OK but there's one weird issue I can't figure out.
It seems like BI is sending lots of data to CPAI because I see endless logs like below when there is no motion on cameras so there should be no AI analysis?
16:24:54:Response rec'd from Object Detection (Coral) command 'detect' (...ec9786) ['Found potted plant'] took 7076ms
16:25:05:Response rec'd from Object Detection (Coral) command 'detect' (...6be3e3) ['No objects found'] took 8678ms
16:25:05:Response rec'd from Object Detection (Coral) command 'detect' (...5835ea) ['Found bed, bed, pizza'] took 8621ms
16:25:07:Response rec'd from Object Detection (Coral) command 'detect' (...21fb70) ['No objects found'] took 8450ms
16:25:13:Response rec'd from Object Detection (Coral) command 'detect' (...d869ea) ['No objects found'] took 7301ms
And as a result, on the BI mobile app I see thousands of alerts!
What am I missing? I can't see any obvious config issues or errors in the log.
Thanks!
Thanks!
