In an outdoor but weather protected environment, the goal is a covert placement of the camera but having the quality of a currently available IP camera with starlight capabilities. I'm suggesting insetting them into portions of a frame structure house wherein the lens will be set to mock the appearance of timber frame pegs from a distance. So I assume there isn't something like this out there and the IP camera/lens portion will have to be taken out of it's housing and inserted into the structure through a drilled hole (drilled through with paddle bit) and the remainder left in the housing mounted behind the structure.
If there is a good quality BULLET style IP camera with excellent night vision qualities in our normal price range, I'd like to hear that suggestion. No on board IR lighting. That will be done with a separate illuminator.
Something this configuration would be perfect, but this is just a cheapie example (I'm guessing) of an analog camera with terrible specs. So if it's not available I'll take a good qual camera apart to achieve this. Suggestions?
I wish for this slender housing with the rest of the components behind the structure out of sight.
