Covered Front Porch camera Placement
Penguintb
Mar 18, 2022
2
Portland Oregon
struggling with camera placement for front door/ house area. using Dahua NVR and have a couple of Andy;s nice turrets.
It is very dark under there without the lights on. Lights on the ceiling every 8 ft.
I have tried different posts and on different sides. tried between windows, (glare). Maybe next to door under light looking out? In the yard? Maybe Boobie cam, mounted to the ceiling in the middle? any suggestions would be greatly appreciated.
What is it that you are struggling with? This part is not clear to me so trying to understand. Sounds like you have tried a few locations, but I did not catch what was not working for you.
I would say boobie cam right where that sun ornament is.
Reactions: sebastiantombs
At night the posts seem to reflect the ir, they are so bright. when I tune the cam in so that the posts don't reflect can't see much.
How are you tuning them in - by lowering brightness or IR and leaving shutter/exposure on auto or are you making a faster shutter?
Which turrets - the 5442 series with Smart IR or the cheaper 2MP without Smart IR?
Here is my "standard" post that many use as a start for dialing in day and night:
Every field of view is different, but I have found you need contrast to usually be 6-8 higher than the brightness number at night.
But first, run H264, smart codec off, CBR, and 8192 bitrate to start, along with 15 FPS and 15 i-frame.
We want the ability to freeze frame capture a clean image from the video at night, and that is only done with a shutter of 1/60 or faster. At night, default/auto may be on 1/12s shutter or worse to make the image bright.
In my opinion, shutter (exposure) and gain are the two most important parameters and then base the others off of it. Shutter is more important than FPS. It is the shutter speed that prevents motion blur, not FPS. 15 FPS is more than enough for surveillance cameras as we are not producing Hollywood movies. Match iframes to FPS. 15FPS is all that is usually needed.
Many people do not realize there is manual shutter that lets you adjust shutter and gain and a shutter priority that only lets you adjust shutter speed but not gain. The higher the gain, the bigger the noise and see-through ghosting start to appear because the noise is amplified. Most people select shutter priority and run a faster shutter than they should because it is likely being done at 100 gain, so it is actually defeating their purpose of a faster shutter.
Go into shutter settings and change to manual shutter and start with custom shutter as ms and change to 0-8.3ms and gain 0-50 (night) and 0-4ms exposure and 0-30 gain (day)for starters. Auto could have a shutter speed of 100ms or more with a gain at 100 and shutter priority could result in gain up at 100 which will contribute to significant ghosting and that blinding white you will get from the infrared or white light.
Now what you will notice immediately at night is that your image gets A LOT darker. That faster the shutter, the more light that is needed. But it is a balance. The nice bright night static image results in Casper blur and ghost during motion LOL. What do we want, a nice static image or a clean image when there is motion introduced to the scene?
In the daytime, if it is still too bright, then drop the 4ms down to 3ms then 2ms, etc. You have to play with it for your field of view.
Then at night, if it is too dark, then start adding ms to the time. Go to 10ms, 12ms, etc. until you find what you feel is acceptable as an image. Then have someone walk around and see if you can get a clean shot. Try not to go above 16.67ms (but certainly not above 30ms) as that tends to be the point where blur starts to occur. Conversely, if it is still bright, then drop down in time to get a faster shutter.
You can also adjust brightness and contrast to improve the image.
You can also add some gain to brighten the image - but the higher the gain, the more ghosting you get. Some cameras can go to 70 or so before it is an issue and some can't go over 50.
But adjusting those two settings will have the biggest impact. The next one is noise reduction. Want to keep that as low as possible. Depending on the amount of light you have, you might be able to get down to 40 or so at night (again camera dependent) and 20-30 during the day, but take it as low as you can before it gets too noisy. Again this one is a balance as well. Too smooth and no noise can result in soft images and contribute to blur.
Do not use backlight features until you have exhausted every other parameter setting. And if you do have to use backlight, take it down as low as possible.
After every setting adjustment, have someone walk around outside and see if you can freeze-frame to get a clean image. If not, keep changing until you do. Clean motion pictures are what we are after, not a clean static image.
