Hi everyone,
I recently installed 4 HikVision cameras (DS-2CD2385FWD-I) and a NVR (DS-7608NI-12). they were all working fine through the console connection, and I decided to do a factory reset on the NVR because i couldn't view the cameras live on the mobile...
anyway, this is the situation I got myself into now:
I am able to login to the NVR, but no live images are showing for any of the cameras
- If I plug my PC into the NVR ports, then the SADP could discover all the cameras and the NVR and, notice that all the cameras do not have a gateway specified - and I assume this might be one of the issues?
- So, I tried to add the gateway with the ip configured for the NVR internal network, it prompts: "error 2015, other" after entering the admin password...
I also tried to reset the camera password, but also failed with error: (in Chinese) "Retrieve information failed. Error sending" I read that it needs to connect to the internet to get the xml export to work - not sure if this is true. But I could only export when connecting to the HikVision "internal network"
So, I'm in a catch 22 situation where the camera does not have a default gateway, and I cannot set it either because of either wrong password or not internet connection...
Any suggestions on what I can do from here? Are the camera supposed to have a default gateway? Thanks.
- when using the "Plug-and-Play" option to connect to the cameras, I'm getting the error: "The user name or the password is wrong"
- when using the "manual" option to connect, with "use channel default password" checked, I'm getting the error: "The network is unreachable.
