Corrupted clips since 4.5.9.6
Tinman
1,530
2,061
USA
Just noticed since last night after I updated to 4.5.9.6 that my recordings have the familiar ghosting and stuttering symptom. Going back to 4.5.9.5 to make sure the problem goes away.
The problem went away after I downgraded....sending Ken a note.
UPDATE: after trying the update again I am not seeing this issue now. Apparently something else was causing the issue or just a bad install.
Reactions: fenderman
What make/model cameras were experiencing the ghosting/stuttering problem? I haven't noticed any issues since updating to 4.5.9.6. I'm using a combination of Hikvision and Dahua cameras.
All Dahua cams with a variety of models. I will try the 4.5.9.6 again and see if it comes back.
I just had a couple of clips and so far 4.5.9.6 is working, so was it a bad upgrade or something ?? I will keep a eye on it and will do a clean boot to make sure something isn't hung.
