I would like to corner mount a mini-ptz sd22204T-GN
According to the accesory selection pdf: http://www.dahuasecurity.com/download/Accessory_Selection2016093059.pdf
You can use a pfa137 which can be mount on a pfa151.
This leads to a vertical mounted ptz which limits the use i think.
An idea would be to mount a pfb202w on a pfa151, so the ptz orientation stays correct.
The mounting holes will not allign but i coud drill new holes.
Anyone tried this before?
