IReallyLikePizza2 Known around here May 14, 2019 2,370 5,621 Houston Jan 25, 2024 #1 Well guys, get your popcorn. This thread will get juicy updates Reactions: looney2ns, Nunofya, fergenheimer and 5 others
IReallyLikePizza2 Known around here May 14, 2019 2,370 5,621 Houston Jan 25, 2024 #3 First activity, spot the Raccoon Reactions: looney2ns, Ssayer, Parley and 3 others
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,336 48,154 Alabama Jan 25, 2024 #4 Reactions: looney2ns, Ssayer, Parley and 1 other person
IReallyLikePizza2 Known around here May 14, 2019 2,370 5,621 Houston Jan 25, 2024 #5 Too easy Next game, fat or pregnant Reactions: looney2ns, Ssayer, Parley and 2 others
T tigerwillow1 Known around here Jul 18, 2016 4,737 10,776 USA, Oregon Jan 25, 2024 #6 I've seen a few of them in live traps and they are vicious beyond description. Total opposite of their cuteness when not triggered. Reactions: looney2ns, Ssayer, Parley and 5 others
IReallyLikePizza2 Known around here May 14, 2019 2,370 5,621 Houston Jan 25, 2024 #7 I plan on using my welding gloves if it gets trapped, hopefully that is good enough Reactions: Ssayer, Parley, JDreaming and 1 other person
97JeepXJ IPCT+ Member Mar 7, 2019 477 1,103 Missouri Jan 25, 2024 #8 Good luck with that. I don’t know what you plan to do after you trap it but they’re in no mood to be messed with after that gate slams shut Reactions: Ssayer, Parley, bigredfish and 3 others
MikeLud1 IPCT Contributor Apr 5, 2017 2,484 4,592 Brooklyn, NY Jan 25, 2024 #9 Try using marshmallows as bait they love them. Reactions: Ssayer, Parley, bigredfish and 1 other person
IReallyLikePizza2 Known around here May 14, 2019 2,370 5,621 Houston Jan 25, 2024 #10 97JeepXJ said: Good luck with that. I don’t know what you plan to do after you trap it but they’re in no mood to be messed with after that gate slams shut Click to expand... It will be going about 20 blocks away
T tigerwillow1 Known around here Jul 18, 2016 4,737 10,776 USA, Oregon Jan 25, 2024 #11 IReallyLikePizza2 said: I plan on using my welding gloves if it gets trapped, hopefully that is good enough Click to expand... Let us know if you change your mind after one of them shows you its teeth . Reactions: fergenheimer, Ssayer, Parley and 6 others
97JeepXJ IPCT+ Member Mar 7, 2019 477 1,103 Missouri Jan 25, 2024 #12 IReallyLikePizza2 said: It will be going about 20 blocks away Click to expand... Better try for more like 5 - 10 miles Reactions: looney2ns, Ssayer, bigredfish and 1 other person
H Heavyopp Getting comfortable Jan 1, 2024 292 422 jersey Jan 25, 2024 #13 IReallyLikePizza2 said: It will be going about 20 blocks away Click to expand... Not far enough Reactions: looney2ns, bigredfish, JDreaming and 1 other person
97JeepXJ IPCT+ Member Mar 7, 2019 477 1,103 Missouri Jan 25, 2024 #14 Unless you plan to dispatch it 20 blocks away, then that’s probably far enough Reactions: bigredfish and JDreaming
bigredfish Known around here Sep 5, 2016 26,055 68,957 The Swamp Jan 25, 2024 #15 TonyR said: View attachment 184153 Click to expand... Guard cat is on point Reactions: JDreaming, looney2ns and Parley
bigredfish Known around here Sep 5, 2016 26,055 68,957 The Swamp Jan 25, 2024 #16 .22 pellet from a Gammo Swarm well placed will take care of it Reactions: JDreaming, looney2ns, 97JeepXJ and 1 other person
IReallyLikePizza2 Known around here May 14, 2019 2,370 5,621 Houston Jan 25, 2024 #17 All I got is 9mm and 556 Will 556 hollow point overpenetrate a coon? So far, its not been to the food. The entrance is sealed to where it will be noticeable on camera if it leaves, and I trawled through the footage in the morning, and I never saw it leave Reactions: JDreaming
bigredfish Known around here Sep 5, 2016 26,055 68,957 The Swamp Jan 25, 2024 #18 55gr may fragment enough, gonna be messy Reactions: JDreaming and 97JeepXJ
IReallyLikePizza2 Known around here May 14, 2019 2,370 5,621 Houston Jan 25, 2024 #19 All I got is 75gr TAP T2, and M193 Don't tell my wife why I'm patching a ceiling hole Reactions: JDreaming and bigredfish
97JeepXJ IPCT+ Member Mar 7, 2019 477 1,103 Missouri Jan 25, 2024 #20 A Gamo break barrel even in .177 can be pretty impressive. They will go through the side of a barn at 80ft if you miss. Only tried that once Reactions: JDreaming, looney2ns and bigredfish
