I've got a new 2CD2432F that came with 5.2.8 firmware onboard and I tried to downgrade it to 5.1.6, which I have running on the other two of my IPCs and which supports my NAS storage properly. Well, after downgrade it went into constant reboot loop. It still capable of updating firmware via TFTP on reboot, but so far none of the code images I have worked (5.1, 5.1.2, 5.1.6, 5.2.0). I don't have 5.2.8 to try either.
I managed to connect UART to it and got a terming log. It looks like it reboots right after starting /home/davinci with the following messages:
Can somebody tell me what's the scoop with it? Is it an unsupported code on the newer hardware or something else?
Code:
U-Boot 1.3.4-100728 (Nov 11 2014 - 13:58:34)
ARM Clock: 480MHz
DDR Clock: 336MHz
Hit Ctrl+u to stop autoboot: 0
|RCV UDP pack timeout|
Unknown command:null
nand booting ...
load kernel...
load ramdisk...
init started: BusyBox v1.19.3 (2013-11-01 10:10:26 CST)
starting pid 378, tty '': '/etc/init.d/rcS'
Starting udev: [ OK ]
starting pid 609, tty '': '/sbin/iptables -A INPUT -p tcp --dport 23 -j DROP'
starting pid 610, tty '': '/sbin/iptables -A INPUT -p tcp --dport 21 -j DROP'
starting pid 611, tty '': '/sbin/inetd -f -e /etc/inetd.conf'
starting pid 612, tty '': '-/bin/sh'
BusyBox v1.19.3 (2013-11-01 10:10:26 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
UBI device number 1, total 192 LEBs (24772608 bytes, 23.6 MiB), available 0 LEBs (0 bytes), LEB size 129024 bytes (126.0 KiB)
waiting for /dev/ubi1_0.
Check dir /dav ok! (0)
UBI device number 3, total 32 LEBs (4128768 bytes, 3.9 MiB), available 0 LEBs (0 bytes), LEB size 129024 bytes (126.0 KiB)
waiting for /dev/ubi3_0.
Check dir /davinci ok! (0)
UBI device number 4, total 32 LEBs (4128768 bytes, 3.9 MiB), available 0 LEBs (0 bytes), LEB size 129024 bytes (126.0 KiB)
waiting for /dev/ubi4_0.
Check dir /config ok! (0)
Hit Ctrl+c to stop and exec /home/initrun.sh to continue
route: ioctl 0x890c failed: No such process
/dav
map_size = 0x300000
nr_item = 3
addr_offset = 0x0 filename = orccode.bin
addr_offset = 0x200000 filename = orcme.bin
addr_offset = 0x2a0000 filename = default_binary.bin
mmap returns 0x4021f000
loading ./orccode.bin...addr = 0x4021f000, size = 0x19f02d
loading ./orcme.bin...addr = 0x4041f000, size = 0x36374
loading ./default_binary.bin...addr = 0x404bf000, size = 0x40000
u_code version = 2013/10/24 3.0
ln: /dev/rtc: File exists
=====check_config start=====
===main db is ok===
==================PPPoE is disable!!!
No need to recover kernel pri partition.
No need to recover ramdisk pri partition.
========capture_mode_pal=0, capture_mode_ntsc=0===============.
powerLineFrequencyMode = 0
[02-20 13:19:41][UNI_IF][ERROR]command = 65
IEfile uncompressed.
get 0-0-0-0.000000-0-0-0
[02-20 13:19:43][HW_IF][ERROR]<INIT485>:x=9,maxBaudIdx=15,/dev/uart1
[02-20 13:19:43][HW_IF][ERROR]<INIT485>set...baudrate=9600,data=3,stop=0,parity=0,flowcontrol=0
<DSP> DBG:init_dsp_lib() begin
<DSP> DBG:init_dsp_lib() end
[02-20 13:19:49][DSP][ERROR][0]g_pdsp->audioTBShare.frameLen=160, g_pdsp->audioTBShare.totalFrame=64..
[02-20 13:19:49][SYSINIT][ERROR]max_fps=0...
mknod: /dev/snd/controlC0: File exists
mknod: /dev/snd/pcmC0D0c: File exists
mknod: /dev/snd/pcmC0D0p: File exists
dsp_init: Unsupported viType=0
# [02-20 13:20:00][SYSINIT][ERROR]hwif_dsp_init error force sys reboot,ret=-12!!!!
