Consumer Cam with usable sound recording..?
krisz707
Jan 4, 2025
11
hungary
Hi Everyone, ive been trying out some consumer bullet cams (because the size thats best for my needs, i need IP rated and small)
as you probably know the sound quality is terrible. what i tried was tapo c320ws, imou bullet 3 and ezviz h3
ive dealt with studio sound recordings and AAC/GSM codecs in the past. these codecs are capable of much better quality than recorded by the cameras.
3 of them are basically the same. they sound like a very strong and badly adjusted, laggy noise gate is on them. possible a bandpass filter also that would be unnecessary for AAC.
the noise floor is set way too high so if theres a heated dialog around the camera, only the louder parts are recorded, and it cuts and stutters elsewhere that makes it unusable to any kind of evidence.
when a loud automobile passes under, they only capture the revs, but not the idling (blurbing)
listenting carefully with my usable sound recording experience tells me the hardware would be enough (so-so), and its the filter/compression combo that screws it. even had the feeling its the same sound algorithm that these companies snatch from each other...?
long story short, can you guys recommend a standalone wifi ip cam that has better sound recording, maybe with some usable settings, that actually do something?
thanks for any input :)
