I think I've run across threads here before with respect to the above, and the performance issues that may be related when trying to do both. What I'm trying to accomplish is, simply, the title. I have (all Hikvision) 2CD2786G2s, an 85G0, a 2DE4A425IW and a KD8003 intercom. All record constantly to a DS-7716NXI-I4 / S to two 8TB WD purples. I have the recordings split across the two, though I don't recall specifically how at the moment. All cameras are set to maximum frame/bitrates.
Normal recording is fine, but it seems the NVR just can't handle that and motion detection events. I assume that said events get their own separate recording, which I don't need. I just want the marker for the event. With motion detection enabled, even live viewing gets a little iffy.
The cameras are fine, and at some point, I may add one or two, and possibly upgrade the PTZ to something better, but ultimately I need a more powerful NVR at a guess. I'm not opposed to rolling my own and I have enough spare hardware at my disposal, including a 32 core Zen3 VM host. Though I do like the idea of simply swapping the existing NVR out for something more up to date.
There's nothing else the NVR is configured for in terms of features, which seems to be somewhat pointless, but the playback performance I've had in the past with constant and motion recording enabled just wasn't cutting it.
Though irrelevant, I'm sure I'll get the why am I doing it this way, because I want to be notified of more pertinent events on/around the property, but still have the ability to see what's up with non-triggered events.
So, is there an appropriate NVR to get off the shelf in this context, or is it a roll my own scenario?
