- Dec 17, 2016
- 7
- 0
A couple of weeks ago I started setting Blue Iris up and have a bunch of cameras added. All was going fine. I stopped using it for a couple of weeks because it wasn't needed yet and came back to it today. It seemed to be working at first but I hadn't really done much other than rename some cameras.
I go into the Options --> Startup tab to turn on the option to autostart/run as a service. I tick that box. I spot the "use a system tray icon" option and think that's not a bad idea so I tick that box and before I can get down to click the OK button Blue Iris crashes.
Then any time I tried to open Blue Iris I get the splash, I get the main window loading for a fraction of a second and then a crash. Event Viewer details:
Crash box pic attached.
Win 7 64-bit SP1 w/ latest updates.
After that I ran an update from here Blue Iris Updates and also re-installed the latest Visual C++ Redist 2013. No change.
I could get into Blue Iris in Safe Mode but of course since I hadn't been able to save/OK the settings earlier they weren't turned on. So I installed the service/autostart.
Then I had trouble maintaining contact with the cameras. If you looked in the status thing they were just constantly flipping between red and black. When I went to the cameras pages everything seemed fine, feed was fine, pinging 100% <1ms. I installed iVMS 4200 v2.5.1.7 and it added all the cameras and could look at the live feeds just fine. All the cameras are also fine if you just go to their internally hosted webpage (don't know the right term for that, go to their IP in your web browser).
Then I completely uninstalled anything camera related (I had HIKVision's SADPtool & iVMS on there for testing), re-installed Visual, re-installed Blue Iris. Added the first camera and it immediately crashed. Same crash details as above:
V5.4.0build 160401 and DSP Version is V7.3 build 160401.
Help?
Faulting application name: BlueIris.exe, version: 4.4.9.4, time stamp: 0x584f2bc2
Faulting module name: BlueIris.exe, version: 4.4.9.4, time stamp: 0x584f2bc2
Exception code: 0xc0000005
Fault offset: 0x0000000001153c4f
Faulting process id: 0x16ac
Faulting application start time: 0x01d258cf9f3292e0
Faulting application path: C:\Program Files\Blue Iris 4\BlueIris.exe
Faulting module path: C:\Program Files\Blue Iris 4\BlueIris.exe
Report Id: df837c24-c4c2-11e6-be38-005056c00008
Faulting process id: 0x3e08
Faulting application start time: 0x01d258ef865a798c
Report Id: c68867bc-c4e2-11e6-bd80-005056c00008
The cameras are a combination of HIK Vision DS-2CD2735F-IS and DS-2CD2145F-IS. Software version is Faulting module name: BlueIris.exe, version: 4.4.9.4, time stamp: 0x584f2bc2
Help?
