I’ve managed several Blue Iris servers since 2021 and generally follow the "don't upgrade unless it's broken" rule. However, after recent CPU spikes on v5 and the need for new iOS push keys, I decided to perform a clean install of v6.
The Issue:
During the v6 install, I repeatedly received errors stating Visual C++ was not installed correctly. I manually installed the latest Redistributables directly from Microsoft (matching the BI requirements), but the BI installer still flagged it. I proceeded anyway, and now the app restarts roughly every hour.
Current State:
I love the power of this software, but the jump to v6 feels unmanageable. I’ve spent days redoing notes because the UI and dependencies shift so frequently. Does anyone have a fix for the C++ installer loop, or am I truly stuck rebuilding from scratch to get stability back?
The Issue:
Current State:
- Clean uninstall of v5 before v6 install.
- Latest Windows updates and MS Visual C++ versions are confirmed.
- I’m considering a full OS wipe and manual reconfiguration (no registry imports) to fix the instability.
